'04 Subaru Impreza WRX STI
Rãspuns: '04 Subaru Impreza WRX STI
« Reply #660 on: March 09, 2017, 14:27:33 PM »
DRY ?
« Reply #661 on: March 09, 2017, 14:31:33 PM »
:D
RCM Dry Sump Kit
RCM in car Oil Tank
STI Spec C Group N Sandwich Plate
STI Group N 2 port water pump
HKS Kevlar timing kit
Hub mounted air vents
Radiator ulei Setrab TMOC
Rear subframe locking down bolts Whiteline
Rear subframe race poly bushing Power Flex
Roll center adjust kit Super PRO
si inca niste piese pt hawk-ul JDM sa il pun pe picioare gen HKS Kevlar timing kit si la el, water pump ej207 EDM, RCM Billet 10mm Oil pump
« Reply #662 on: March 09, 2017, 14:35:07 PM »
sa curga baluta in continuare
  • 14138
« Reply #663 on: March 09, 2017, 15:15:05 PM »
Pfff...
« Reply #664 on: March 09, 2017, 15:17:06 PM »
SA MOARA FANII , uite juma de garaj unde e :) ! sa le folosesti sanatos miez , sa dam niste timpi pe speluncata zic ...
« Reply #665 on: March 09, 2017, 15:32:31 PM »
corect nooo :) merci merci da astept cu mare interes, apropo am identificat si treaba cu sensorul primar O2, este un senzor de spec c cu cablaraia lungita deci rezolv in sf si acel CEL ordinar...
« Reply #666 on: March 09, 2017, 15:42:57 PM »
p0rn!
  • 1806
« Reply #667 on: March 10, 2017, 02:21:36 AM »
Sa moara draq! Mi s a bulbucat un ochi si a ramas asa o.O
daniel.gugu
  • 1384
  • Forester & Impreza
    • http://www.gg-dc.ro/
« Reply #668 on: March 10, 2017, 05:32:28 AM »
Acum imi explic de ce salivez incontinuu de aseara ... Bravo man ... ne-ai aratat cireasa de pe tort!
Subaru Impreza Type R - GOOFY
« Reply #669 on: March 10, 2017, 12:23:34 PM »
:))) sa nu fim chiar asa de nebuni... merci baietii
« Reply #670 on: March 10, 2017, 12:59:40 PM »
Ce anume sunt acelea  din pozele de mai sus ? Merci .
Pedal to the Metal !
WRX.STI 2017- Sport
etc, etc, etc
« Reply #671 on: May 22, 2017, 15:07:04 PM »
in caz ca vreti sa pierdeti niste timp, 2 curse de aseara de simracing unde m-am dat eu si zgb
&t=6658s&index=5&list=WL  de la 1:19.00 incepe prima cursa
daniel.gugu
  • 1384
« Reply #672 on: May 23, 2017, 05:16:25 AM »
Frumoasa cursa !!!
« Reply #673 on: May 23, 2017, 10:25:32 AM »
Deci am stat 15 min sa caut Blob-ul tau sau numele pe tabela, dupa care m-am prins ca e un joc video :))))))))
« Reply #674 on: May 23, 2017, 11:28:33 AM »
am vaz cursele live , felicitari !!!
  • 14138
Răspuns: '04 Subaru Impreza WRX STI
« Reply #675 on: May 23, 2017, 13:06:17 PM »
Man, perla aurie din vopseaua neagra e doar la STi? :D
« Reply #676 on: May 23, 2017, 14:51:52 PM »
merci merci, eram cu numele meu inscris dar din pacate cu gunoiul alea de fwd-uri...
miez e mai complicat cu vopseaua, java black sau negru cu perla aurie a fost doar pe sti-urile 2004 si a fost celebratorie ca au luat wrc-ul in 2003
Re: '04 Subaru Impreza WRX STI
« Reply #677 on: June 15, 2017, 15:07:33 PM »
ca sa nu poluez topicul de onboard cu simracing, mai pun aici cateva filmari recente. in weekend o sa fie cursa live la etapa noua de la Portimao, daca mai intereseaza pe cineva sa se uite la simracing o sa pun un link
« Last Edit: June 15, 2017, 15:29:10 PM by STI »
« Reply #678 on: June 20, 2017, 16:50:15 PM »
duminica mi s-a ars pc-ul de munca, deci o perioada o sa fiu mai inactiv, pt oricine doreste sa intrebe de ceva sau alte probleme imi puteti da mesaj privat aici pe forum, merci.
« Reply #679 on: July 11, 2017, 02:48:23 AM »
cursa dubla de wtcc de weekendul trecut de la SPA, actiunea interesanta incepe pe la 1h:15min, si sunt 2 curse una dupa alta
« Last Edit: July 11, 2017, 02:50:07 AM by STI »
