Subaru Impreza Boxer diesel
Răspuns: Subaru Impreza Boxer diesel
« Reply #20 on: October 18, 2012, 21:59:34 PM »
ms naiman... tu la 1 mil ai ajuns? :))
naiman
  • 307
« Reply #21 on: October 19, 2012, 07:26:31 AM »
Eu la 105 500 km dintre care 5 500 in ultimii 2 ani jumate ca a stat masina pe dreapta dar acum merg zi de zi cu ea si incep sa se adune :)
« Reply #22 on: November 08, 2012, 08:43:42 AM »
Ce bine arata grila fata...
De unde ai luat strub brace-urile CUSCO si paravanturile si la ce bani? Multumesc.
« Last Edit: November 08, 2012, 11:46:08 AM by KET »
« Reply #23 on: November 09, 2012, 00:18:53 AM »
Strut bar-u din spate este luat de la Alex Mirea, cel de pe fata este luat de pe RHDJAPAN.COM si a fost undeva la 177Euro cu tot cu transport, iar paravanturile le gasesti http://www.paravant.ro/ sunt undeva la 150 Ron, sunt marca HEKO si le recomand (eventual apeleaza id-ul de yahoo xenonparavanturi este un baiat super ok)
« Reply #24 on: December 14, 2012, 00:37:50 AM »
in the middle of nowhere... just another day at work
Uploaded with ImageShack.us
naiman
  • 307
« Reply #25 on: December 14, 2012, 07:25:57 AM »
Frumoa asa, toata lumea are zapada numai la tulcea si constanta nimic :(
Pune poza si la fotografia lunii ca merta ;)
« Reply #26 on: December 14, 2012, 09:02:06 AM »
Da, foarte frumoasa fotografia. Ii sta foarte bine masinii asa murdara in zapada... Zapada vrem si noi!
« Reply #27 on: February 02, 2013, 12:14:09 PM »
DPF off... remap
Fab
  • 794
« Reply #28 on: February 02, 2013, 12:35:41 PM »
Cam bine! ;D
« Reply #29 on: February 02, 2013, 13:17:49 PM »
cam da...
nice...
tar0M
  • 934
  • Impreza WRX 2008
« Reply #30 on: February 02, 2013, 13:23:49 PM »
Care sunt diferentele in urma schimbarii?
  • 1669
« Reply #31 on: February 02, 2013, 14:14:50 PM »
wow! 190 cp si 420 NM !!!  :o :o :o
e ceva... cum e masina acum? vad ca ai schimbat si evacuarea cap-coada...cine a facu evacuarea? e custom?
Fab
  • 794
« Reply #32 on: February 02, 2013, 14:20:06 PM »
Alin, trebuie sa ne intalnim candva sa ma dai si pe mine o tura. ;D ;D
« Reply #33 on: February 02, 2013, 15:07:30 PM »
Evacuarea este 90%stock, are dat jos doar DPF-ul care era in partea din fata, iesirea din turbina 50-60cm lungime si inlocuit cu un downpipe facut la baietii de la Topgear, softul este facut de Nadir la Exelisis, masina avea soft inainte de la Superchips, acum a fost resoftata pt anularea DPF si o crestere minora de putere (5-10cp max). Diferenta este ca inainte sa dau DPF-ul jos ma bucuram de puterea masinii f rar, pt ca filtrul de particule se infunda des si isi facea regenerare.Am mers cu masina in limpmode pana la Bucuresti, limitata la 3600-3700rpm, check-rule aprinse, si beculetul de la DPF clipacind. Acum a mai ramas doar beculetul de la DPF care clipane, nu am putut sa il stingem, dar nu ma deranjaza atata timp cat nu mai am alte erori si masina merge ok. Pobabil daca nu ii dau de cap o sa il scot din bord, si asa nu mai exista fizic dpf-ul.
« Reply #34 on: March 05, 2013, 23:51:29 PM »
editat pe motiv de protest :) 18.03.2019
« Last Edit: March 18, 2019, 11:21:58 AM by andea79 »
  • 1806
« Reply #35 on: March 05, 2013, 23:56:05 PM »
Nu vreau sa mai aud de motoare sparte..Succes cu motorul!
« Reply #36 on: March 06, 2013, 09:05:41 AM »
125mi km si inca rezista, schimbu de ulei il fac sub 10 mi, acum... ce o fi o fi... oricum sper ca in luna aprilie asta sa treaca pe locul doi, vreau si eu un GC la care sa pot face mai multe, la asta sunt limitat
« Reply #37 on: March 06, 2013, 11:05:52 AM »
:D felicitari :D GC o sa te cucereasca :D
« Reply #38 on: March 13, 2013, 09:29:30 AM »
Updates... am stins becul de la DPF care ramasese intermitent. Aseara mecanicul meu cu un tester universal a avut optiunea de "DPF has been changed" care in mod normal se da dupa ce se schimba DPF-ul. ECU a invatat noile valori (adica cele fara DPF) si becul s-a stins. Smart this Subaru ECU
« Reply #39 on: October 18, 2013, 12:03:46 PM »
Inca un diesel praf, nu a crapat arborele dar are bataie,de luni o fac bucati sper sa nu fie prea grav noroc ca am sesizat bataia si nu am asteptat sa crape. In alta ordine de idei nici problema cu apa nu se rezovlase imi baga aer/gaze in instalatie si fenomenu s-a inrautatit in timp... banuiesc garnitura de chiuloasa. Sper sa scap usor... updates si poze de luni
