OEM Subaru Wheel Specs
« on: May 29, 2013, 16:19:51 PM »
Intentionez ca acest subiect sa fie o baza de date cuprinzatoare de jante Subaru OEM.
Voi da cat pot de multe informatii si imagini pentru fiecare in parte.
98-99 Impreza 2.5RS
Offset: +53
Bolt pattern: 5x100
Wheel Weight: 7.48kg
OEM-equipped tire size: 205/55R16
2000-01 Impreza 2.5RS
Offset: +53
Bolt pattern: 5x100
Wheel Weight: 7.25kg
2002-04 Impreza
Offset: +55
Bolt pattern: 5x100
Wheel Weight: ?
2002-05 WRX
Offset: +53
Bolt pattern: 5x100
JDM/EDM 2004 WRX
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 8.6kg
OEM-equipped tire size: 225/45R17?
2005-06 Impreza
Offset: +55
Bolt pattern: 5x100
Wheel Weight: ?
JDM/EDM STi version 7
Offset: +53
Bolt pattern: 5x100
Wheel Weight: 7.93kg
2006-07 WRX
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 9.52kg
OEM-equipped tire size: 215/45R17
2004 WRX STi BBS
Offset: +53
Bolt pattern: 5x100
Wheel Weight: 7.12kg (forged)
2005-07 WRX STI BBS
Offset: +53
Bolt pattern: 5x114.3
Wheel Weight: 8.61kg (forged)
2007 WRX STI Limited Enkei
Offset: +53
Wheel Weight: ?
OEM-equipped tire size: 235/45R17
2008 Outback Sport
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 10.25kg
OEM-equipped tire size: 205/50R17
2008 2.5i Impreza
Offset: +55
Bolt pattern: 5X100
Wheel Weight: 9.16
2008-2010 WRX
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 10.52kg
OEM-equipped tire size: 205/50R17 (2008), 225/45R17 (2009-10)
2008 STi five-spoke
Offset: +55
Wheel Weight: 12.x kg
OEM-equipped tire size: 245/40R18
2008-2011 STi BBS
Offset: +55
Wheel Weight: 9.29kg (forged)
2011 WRX
Offset: +53
Bolt pattern: 5x100
Weight: 9.97kg
2011 STi Enkei
Offset: +55
Wheel Weight: 10.68kg
Notes: This wheel was also offered on the 2010 STI Special Edition, in a darker color.
2012 Impreza Sport
Offset: +48
Bolt pattern: 5x100
Weight: ?
2012 Impreza Premium
Offset: +48
Bolt pattern: 5x100
Weight: 8.43kg (estimate)
2012 Impreza Limited
Offset: +48
Bolt pattern: 5x100
Weight: ?
2012 STI Enkei
Offset: +55
Bolt pattern: 5x114
Wheel Weight: 12.06kg
1998 22B BBS
Offset: +48
Bolt pattern: 5x100
Wheel Weight: ?
OEM-equipped tire size: 235/40R17
« Last Edit: May 29, 2013, 16:34:17 PM by paulwhp »
Rãspuns: OEM Subaru Wheel Specs
« Reply #1 on: May 29, 2013, 16:22:31 PM »
1997-2004 Legacy GT
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 9kg
2005-06 Legacy GT
Offset: +55
Bolt pattern: 5x100
2006-07 Outback
Offset: +48
Bolt pattern: 5x100
Wheel Weight: 9kg
OEM-equipped tire size: 225/55R17
2007-09 Legacy GT
Offset: +55
Bolt Pattern: 5x100
Weight: ?
OEM tire size: 215/45R17
2008 Outback XT/LL Bean
Offset: +48
Bolt pattern: 5x100
Wheel Weight: ?
2008-09 Legacy GT Spec B
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 11.56kg
OEM-equipped tire size: 215/45R18
JDM Legacy B4
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 8.16kg
OEM-equipped tire size: 215/45R17?
2010 Legacy GT
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 11.52kg
OEM-equipped tire size: 225/45R18
2013 BRZ (and FR-S)
Offset: +48
Bolt pattern: 5x100
Wheel Weight: 9.11kg
Poza lipsa.
2013 Legacy steelie
Offset: ?
Bolt pattern: 5x100
Wheel Weight: 9.97kg
OEM-equipped tire size: 205/60R16
2013 Crosstrek XV alloy
Offset: +20? (need confirmation)
Bolt pattern: 5x100
Wheel Weight: ?
« Last Edit: May 29, 2013, 16:36:44 PM by paulwhp »
  • 14140
« Reply #2 on: May 29, 2013, 18:15:54 PM »
Bun! Si eu ma gandeam sa copiez de pe nasioc sau iwsti la un moment dat toata informatia, dar am fost cuprins de o leneee...
Merci!
« Reply #3 on: May 29, 2013, 19:12:00 PM »
buna idee topicului, dar greutatile la unele jante sunt eronate din cate stiu, gen la jantele de sti 03-07
« Reply #4 on: May 29, 2013, 19:38:49 PM »
E greutatea de pe forumul lor, nu am verificat.
« Reply #5 on: May 29, 2013, 22:30:16 PM »
Alea de doispe kile s tari....12kg?....La SMT era 80 mil bucata....;D
« Reply #6 on: May 30, 2013, 00:20:45 AM »
taiate cu plasma direct din capacul de canal, rezistente la gropi ! suna acum si le iei doar 80 mil !
