Gratie cometariului postat de Strepsils am recitit cu atentie cartea tehnica si am constatat, cu emotii si stupoare, ca pentru modelul Forester 2015 Turbo este chiar indicat a se folosi o benzina cu cifra octanica 98 sau superioara...
Iata ce scrie in ghidul de utilizare al masinii mele:
"Fuel CAUTION
Use of a fuel which is low in quality or use of an inappropriate fuel additive may cause engine damage.
Fuel requirements
Non-turbo models
The engine is designed to operate using unleaded gasoline with an octane rating of 87 AKI (90 RON) or higher.
Turbo models
The engine is designed to operate at maximum performance using unleaded gasoline with an octane rating of 93 AKI (98 RON) or higher. If 93 AKI (98 RON) fuel is not readily available, unleaded gasoline with an octane rating of 91 AKI (95 RON) or higher may be used with no detriment to engine durability or driveability.
However, you may notice a slight decrease in maximum engine performance while using 91 AKI (95 RON) fuel.
Regular unleaded gasoline with an octane rating of 87 AKI (90 RON) or higher may also be used. Using regular unleaded gasoline will not be detrimental to engine durability, nor will it affect your warranty coverage. However, depending on your
driving habits and conditions, you may notice a decrease in maximum engine performance, fuel economy or slight engine vibration or knocking. If you experience any of these conditions while using a lower octane rated fuel, you may want to return to using 91 AKI (95 RON) octane rated fuel as soon as possible. Additionally, if your vehicle knocks heavily or persistently, or if you are driving with heavy loads such as when towing a trailer, the use of 91 AKI (95 RON) or higher grade unleaded gasoline is required."
In concluzie, adio benzina de 95!
