Am sa pun mai jos descrierea oficiala a sistemului SI-Drive asa cum vine ea de la Subaru. Din pacate este in engleza si daca aveti probleme cu traducerea va putem ajuta.
Intelligent (push down on the knob) – smoothness * Improved drivability in inclement weather – the engine is less sensitive to movement of the accelerator pedal
* Smoother operation in traffic, with moderate power delivery
* Increased fuel economy by up to 10 percent
* Well-balanced performance
Sport (turn the knob counterclockwise) – linearity * Linear power delivery – engine response is almost in direct proportion to accelerator pedal movement
* Quick throttle response
* Ideal for day-to-day, all-around performance driving
* Fun-to-drive feel – to help make the driving experience a personal adventure
Sport Sharp (turn the knob clockwise) – responsiveness * Rapid power delivery – engine response reaches 100 percent with approximately 54 percent accelerator pedal movement
* Added performance edge (close to the feel of an Impreza WRX STI)
* Quicker throttle response
* Quicker engine power delivery
* Greater torque at lower engine speeds
* For exhilarating, maximum-performance driving
SI-DRIVE CHANGES A VEHICLE’S PERSONALITY – FROM FUEL-EFFICIENT CRUISER TO HIGH-PERFORMANCE MUSCLE CAR.As a student studying the internal- combustion engine, Toshio Masuda foresaw a time when engines would be able to change characteristics without replacing systems within them. Later, as Project General Manager of Legacy and Outback for Subaru, he found support for his ideas, and the end result is SI-DRIVE – an engine control that electronically alters how an engine operates.
Today, SI-DRIVE is found in 2008 Subaru Legacy and Outback models with turbocharged and six-cylinder engines. This feature allows the driver to manage the vehicle’s electronic engine and automatic-transmission controls by switching between three modes.
SI-DRIVE’s purpose is to maximize engine performance, control, and efficiency. As conceived by Mr. Masuda, SI-DRIVE has the effect of giving a vehicle three different engines in one.
THREE ENGINES IN ONEThe modes are selected by a knob located behind the shifter, and they’re marked Intelligent, Sport, and Sport Sharp. (A Sport Sharp button is added to the steering wheel for 2008.) The selected mode is shown in the multifunction display window in the instrument panel along with a representation of the corresponding torque curve.
Choosing a mode sends signals to the vehicle’s body control module. From there, wiring carries signals almost instantaneously to the engine’s and automatic transmission’s electronic control units. The SI-DRIVE settings change the control units’ programming (mapping).
Programming changes modify engine torque characteristics by adjusting how engine and transmission components function. These components include the electronic throttle, fuel delivery system, ignition, turbocharger wastegate, and automatic transmission response.
Intelligent: With its moderate power delivery and smooth drivability, this mode is ideal for around-town driving and for difficult driving conditions such as slick roads or loose surfaces. It is the most fuel-efficient of the three modes.
Sport: This mode is versatile, providing linear acceleration that is as ideal for freeways and suburban streets as it is for climbing mountain roads.
Sport Sharp: Delivering maximum driving enjoyment, this mode is ideal for tackling twisting roads and for confidently merging or overtaking other vehicles on the highway
SI-DRIVE SAFEGUARDSThe SI-DRIVE system can sense when a potential engine or transmission problem may exist, and it will react to help prevent damage.
For example, if the CHECK ENGINE warning light/malfunction indicator light illuminates while the engine is running, SI-DRIVE automatically resets to Sport mode. When the light is on, changing to either Sport Sharp mode or Intelligent mode is not possible.
![](http://img638.imageshack.us/img638/2586/displaycomponents.jpg)
Also, if the temperature of the engine coolant increases to the point of possible overheating, selection of the Sport Sharp mode is not possible. If the selector is in Sport Sharp when engine temperature reaches a certain point, the system automatically resets to the Sport mode.
Similarly, the SI-DRIVE selectors in Legacy and Outback models with 3.0-liter engines automatically reset to Sport mode when engine oil temperature increases.
