Subaru Forester 2.0D 2008
Cif
  • 3
  • My Pet Spider : /^(o.o)^\
« on: December 05, 2019, 08:18:05 AM »
Salut si bine v-am gasit.
Proaspat posesor de Forester. Il am de aproximativ doua luni cu vreo 4000 de km facuti. Masina are motorul schimbat in 2016 la reprezentanta din Kecskemet Ungaria.
Issues(so far): Nu merge degivrarea  pe oglinda din stanga.
Re: Subaru Forester 2.0D 2008
« Reply #1 on: December 05, 2019, 09:01:28 AM »
Salutare si bine ai venit in grupul Subaristilor !
  • 2272
« Reply #2 on: December 05, 2019, 11:43:15 AM »
Bine ai venit !
Referitor la oglinda - se poate sa fi fost schimbata. Prost !
Adica, fie au pus una fara degivrare (desi nu cred ca au fost din astea pe Forester), fie nu au facut legaturile electrice.
Asta daca la cea din dreapta merge.
Altfel, poate fi o siguranta arsa.
Cif
  • 3
« Reply #3 on: December 05, 2019, 18:45:06 PM »
Am gasit asta pe un site. Chiar asa simplu o fi?
CAUTION:
When installing the mirror, insert the worm securely.
1. Face the mirror upward.
2. Disconnect the ground cable from battery. (Model with mirror heater)
3. Lift the lower part and the outer side of the mirror, and remove the connections (1) and (2).
4. Disconnect the mirror heater connector. (Model with mirror heater)
5. Attach the mirror to the connection (1), and attach the worm to the connection (2).
Cif
  • 3
« Reply #4 on: December 05, 2019, 20:26:51 PM »
Am descalcit misterul. Am dat oglinda intr-o parte si am vazut doua fire care atarna prin carcasa. Deci sticla e fara degivrare. :(
« Reply #5 on: December 05, 2019, 21:43:49 PM »
Foarte frumoasa culoarea. Sa il stapanesti sanatos!
