Am gasit asta pe un site. Chiar asa simplu o fi?
CAUTION:
When installing the mirror, insert the worm securely.
1. Face the mirror upward.
2. Disconnect the ground cable from battery. (Model with mirror heater)
3. Lift the lower part and the outer side of the mirror, and remove the connections (1) and (2).
4. Disconnect the mirror heater connector. (Model with mirror heater)
5. Attach the mirror to the connection (1), and attach the worm to the connection (2).
