Pornire grea la rece
Re: Pornire grea la rece
« Reply #100 on: January 26, 2018, 11:49:39 AM »
Eu n'as plia oglinzile in perioada asta ...
« Reply #101 on: January 26, 2018, 13:39:00 PM »
Si asa porneste al meu:
https://youtu.be/rgN_Sf0o7Oo
  • 5296
« Reply #102 on: January 26, 2018, 13:41:59 PM »
Adica:
- face multe ture de demaror;
- porneste la 1000 rpm pentru cateva secunde;
- abia APOI urca la 2000.
Si tu te plangi??  >:( >:( >:(
Lasand gluma (si nu prea), ai o problema p-undeva.
« Last Edit: January 26, 2018, 13:44:10 PM by Muttley »
« Reply #103 on: January 26, 2018, 13:53:45 PM »
Dragos, tu ai ceva probleme de senzori, IACV, soft, etc..
Yeti, si a mea, nepornita de ieri seara:
https://youtu.be/LNv-Qy1uJjE
« Last Edit: January 26, 2018, 15:21:39 PM by Pfaizzzer »
  • 5296
« Reply #104 on: January 26, 2018, 14:33:58 PM »
Pfaizar,
1) cu ce drac ai filmat, cu lumanarea???  :laugh:
2) nu apare pe film chinele ala tolomac  :laugh: :laugh: Pardon, chiar apare!!! =)))))))))
3) ce ciasuri urate...  :P
Ontopic: data fiind temperatura de afara, as zice ca n-am probleme cu alea 2000 de ture la -10*C. Am sa fiu atent peste 2 ore, cand o pornesc, pana unde sare. Revin. Chiar daca-s agasant  ^-^
Edit: o explicatie ar fi uleiul 0W50 poate pentru turatia aia mare... Un 5W30 poate ar fi infranat motorul... Dunno.
Edit 2: tot 2k rpm. O vand!!!
« Last Edit: January 26, 2018, 17:07:30 PM by Muttley »
« Reply #105 on: January 26, 2018, 14:50:19 PM »
Pfaizar,
4) Inpreza WRX 2001 ?  >:D ;D
« Reply #106 on: January 26, 2018, 15:16:42 PM »
@Pfaizzzer: Eu am ramas fascinat atat de procedura tehnica de pornire, prin rotirea completa a butonului de lumini de doua ori, cat si de incantatiile care se auzeau, in polifonie, pe fundalul sonor astfel incat demarorul a devenit o simpla compozitie ambulanta si auxiliara intr-un aranjament orchestral... ;D
« Last Edit: January 26, 2018, 15:32:19 PM by Heliotropus »
« Reply #107 on: January 26, 2018, 15:16:47 PM »
Da, e model de Elvetia si se scrie cu “n”.
  • 1741
« Reply #108 on: January 26, 2018, 15:19:45 PM »
De regula nu le pliez , dar acum e parcata pe o straduta din Sibiu si am zis sa le las pliate peste noapte. Oricum, le pliez foarte delicat.  :)
In alta oridine de idei cum vi se pare pornirea la masina mea?
Dragos Aron , daca o lasi sa invarta mai mult nu porneste? Pare ca ai oprit-o tu din cheie
« Reply #109 on: January 26, 2018, 15:25:54 PM »
Uxe, suna cam “neregulat”, dar o ia.
Parca vad ca discutia asta ajunge la “Loc de dat cu capul” :))), cu ajutorul lui Heliotropus, bineinteles.
Si pentru fani, am urcat varianta HD.
  • 5296
« Reply #110 on: January 26, 2018, 16:01:10 PM »
Te paste un rebuild.
« Reply #111 on: January 26, 2018, 16:22:01 PM »
ot:
@UXE: am presupus ca ai plierea electrica, daca e manuala e ok, nu risti sa fortezi vreun motoras
  • 1741
« Reply #112 on: January 27, 2018, 08:58:11 AM »
Pornirea de azi dimineata
https://youtu.be/ZpCdCBRaHKw
« Reply #113 on: January 27, 2018, 17:14:05 PM »
@UXE, ba da, porneste daca o las sa invarta mult da nu imi place. Prefer sa invart de cateva ori la prima cheie ca sa o ia imediat la a doua :)
@Pfaizzzer, asa am zis si eu dar Mihai F a schimbat tot ce i-a trecut prin cap si nici-o diferenta, Mihai S i-a facut soft, eu inca vreo 3 si face la fel :) Maine vin la Bv daca ai vreo varianta pe care o putem verifica :)
  • 14140
« Reply #114 on: January 27, 2018, 18:25:54 PM »
Singurul neschimbat din ce zice pfaizzzer este senzorul de turatie.
In rest, IACV curatat, aveam si tutorial facut, senzor pozitie axa cu came schimbat. Eu mergeam cu softul de fabrica.
« Reply #115 on: January 27, 2018, 19:10:12 PM »
Poate reusim sa vedem ce valori da senzorul de turatie daca punem laptopul. In rest nu prea avem ce sa facem. Da un semn si facem un brainstorming.
  • 1741
« Reply #116 on: January 28, 2018, 10:35:15 AM »
  • 5296
« Reply #117 on: January 28, 2018, 13:34:37 PM »
Stii ca la Subaru, pornirile de luni dimineata-s cu problema. Asteptam filmul de maine.
  • 1741
« Reply #118 on: January 28, 2018, 19:33:39 PM »
Gata concediul. Maine merg cu renoul.  :P
« Reply #119 on: October 29, 2018, 15:59:29 PM »
Informatii preluate din industria auto:
"1. Lichidul pentru curatare parbriz
Este recomandabil sa folositi un lichid special pentru spalarea parbrizului care nu ingheata la temperaturi negative, trebuind sa reziste la o temperatura de cel putin -20o C. Rezervorul de lichid pentru spalat parbrizul este indicat sa fie tinut la un nivel aproape de maxim. Datorita concentratiei destul de mari de alcool, lichidul nu va ingheta, insa exista posibilitatea sa se intample lucrul acesta cu eventualele cantitati mici ce pot ramane pe furtunasele ce duc la duzele de pe capota sau la faruri. Astfel, parbrizul nu mai poate fi curatat corespunzator, iar in cazul deplasarilor pe autostrada sau drumuri nationale, poate fi pusa in pericol siguranta proprie si a celorlati participanti la trafic. De asemenea, pompa si rezervorul de lichid pot fi distruse prin inghetarea acestuia.
2. Amestecul de antigel
Verificati concentratia de antigel din sistemul de racire al masinii in unitatile service. Daca nu este suficient antigel, circuitul de racire al motorului poate ingheta si astfel poate provoca daune importante. Antigelul este necesar si la temperaturi pozitive, deoarece protejeaza de coroziune si creste temperatura de fierbere a lichidului de racire. Atentie la alegerea antigelului, fiind necesar sa respectati indicatiile producatorului. Circuitul de racire poate fi distrus ca urmare a utilizarii unui amestec de substante nepotrivite. In perioada de iarna, este indicat sa verificati periodic punctul de inghet al lichidului de racire si, la nevoie, sa completati cu antigel. Daca limita de inghet este prea ridicata, completati cu antigel pana cand se ajunge la nivelul dorit. Aceasta trebuie sa fie in jurul valorii de -35o C, pentru Romania.
3. Stergatoarele de parbriz
Daca stergatoarele sunt deteriorate, ele trebuie schimbate, durata medie de viata a acestora fiind de 1 an. In cazul in care acestea nu lucreaza eficient, este greu sa obtineti o vizibilitate buna, iar pe timp de iarna acest lucru este foarte important, conditiile atmosferice fiind mai grele decat in restul anului. Pentru a nu le scurta durata de viata, nu utilizati stergatoarele pe geamul inghetat.
In masura in care stergatoarele sunt blocate din cauza depunerii de gheata, nu actionati comanda electrica intrucat motorul mecanismului va fi activat si va ramane sub tensiune, putand fi deteriorat.
4. Becurile
Verificati daca instalatia de iluminare a masinii functioneaza corect si daca exista becuri arse sau care nu ilumineaza corespunzator. Este util sa aveti un set de becuri de rezerva in masina, pentru cazuri de urgenta. De asemenea, este necesara verificarea unghiului de iluminare a farurilor si, daca este cazul, reglarea acestuia.
5. Sistemul electric
Asigurati-va ca sistemul de dezghetare a lunetei si oglinzilor functioneaza corect. Chiar daca este iarna si temperatura in habitaclu in mod sigur nu este prea mare, este indicat ca macar o data pe luna sa porniti sistemul de aer conditionat sau climatizare timp de 10-15 minute, din motive ce tin de intretinerea acestora.
O problema ce apare in mod constant iarna, atunci cand temperatura exterioara este mult mai mica decat cea interioara, este reprezentata de geamurile aburite. Pentru a scapa de acest impediment, folositi ventilatorul aerotermei pe trepte mai mari decat de obicei, cu sistemul de aer conditionat activ, astfel incat in masina sa se creeze curenti de aer cu rol dezumidificator.
6. Sistemul de franare
Verificati instalatia de franare. Aceasta trebuie sa functioneze ireprosabil si placutele sa nu prezinte uzura avansata. Daca placutele uneia dintre roti sunt foarte uzate, masina nu va frana liniar si puteti avea surpriza unui derapaj lateral la o frana mai puternica pe zapada.
Este bine sa nu folositi frana de mana atunci cand se inregistreaza temperaturi scazute. Cablul care actioneaza sistemul poate ingheta si puteti avea surpriza neplacuta de a nu putea elibera frana. In cazul in care se intampla acest lucru, turnati apa calda pe rotile spate pana cand se deblocheaza. Nu fortati deplasarea cu rotile blocate, intrucat exista riscul de a deteriora sistemul de franare spate si/sau anvelopele.
7. Curele si furtunuri
In mod uzual aceste elemente au o durata lunga de utilizare. Verificati gradul de uzura inainte de sosirea anotimpului hibernal, intrucat temperaturile scazute accelereaza deteriorarea lor.
8. Acumulatorul
Cand temperaturile sunt scazute, puterea unei baterii se reduce. Verificati densitatea si nivelul electrolitului in baterie, precum si gradul de incarcare, in unitatile service. Este necesara si verificarea functionarii alternatorului in vederea utilizarii unei tensiuni de incarcare corecte. Operatiunea se realizeaza in cateva minute si veti avea certitudinea ca masina va porni in decursul sezonului rece.
Iarna, ziua este mai scurta, luminile sunt folosite aproape permanent, aeroterma functioneaza pentru a asigura incalzirea habitaclului, stergatoarele si dezaburirea sunt utilizate mult mai des. Concluzia ar fi ca sunt mai multi consumatori in functiune si, de aceea, este nevoie sa ne asiguram ca acumulatorul este in regula. In plus, daca deplasarile sunt pe distante scurte, bateria nu se incarca suficient. Ca urmare, la un moment dat, acumulatorul nu va mai face fata, iar motorul nu va mai porni. In situatiile extreme, acumulatorul nu mai poate fi recuperat.
Motorul poate fi pornit doar daca primeste curent de la alta masina sau daca acumulatorul este incarcat de la prize, cu ajutorul unui redresor. In situatia in care pornirea se face prin alimentare de la acumulatorul unei alte masini, este recomandat sa procedati astfel:
- cablul rosu se conecteaza la plusul acumulatorului masinii in pana si apoi la plusul acumulatorului masinii care da curent;
- cablul negru se conecteaza la polul minus al acumulatorului masinii care da curent si apoi la o piesa metalica neizolata din compartimentul motor al masinii ramase in pana.
Este de mentionat faptul ca acumulatorul donator ar trebui sa aiba capacitate egala sau mai mare cu a celui care trebuie resuscitat si ca este imperativ necesar ca ambele sa aiba aceeasi tensiune - nu vom utiliza un acumulator de 12 volti pentru reanimarea unuia de 24 de volti sau invers.
9. Esapamentul
Iarna circulam cu geamurile inchise. Este, de asemenea, posibil sa ramaneti inzapeziti, cu esapamentul poate ingropat in zapada, gazele de esapament avand posibilitatea sa patrunda in masina. Pentru a evita acesta situatie foarte periculoasa, verificati toba de esapament si toata coloana dintre aceasta si galeria de evacuare.
10. Covorasele din cauciuc
Pentru a proteja mocheta din interiorul masinii, este recomandat sa folositi covorase de cauciuc care sa opreasca apa.
11. Ustensile utile pe timp de iarna
O racleta pentru curatarea parbrizului si a farurilor, cat si un spray special, care ajuta la topirea ghetii depuse pe geamuri, sunt intotdeauna utile iarna in masina. De asemenea, sunt recomandate cabluri pentru alimentarea bateriei, trusa de lanturi corespunzatoare rotilor masinii, o perie pentru zapada, spray pentru dezghetarea incuietorilor, manusi si rezerva pentru lichidul de spalare a parbrizului.
Inainte de a pleca la un drum lung in afara localitatii, aveti grija de cateva aspecte importante: asigurati-va ca aveti bateria de la telefonul mobil incarcata, incercati sa aveti in masina un sac de nisip si o lopata, alimentati masina de fiecare data cand aveti ocazia, motorul fiind singura sursa de caldura daca va inzapeziti. O lanterna, manusi, haine calduroase, apa si mancare sunt, de asemenea, importante pentru siguranta dumneavoastra."
