Din manualul Forester 2007 MT (ca io la AT n-am carte
Manual transmission vehicle
1. Apply the parking brake.
2. Turn off unnecessary lights and accessories.
3. Press the clutch pedal to the floor and
shift the shift lever into neutral. Hold the
clutch pedal to the floor while starting the
engine.
The starter motor will only operate when
the clutch pedal is pressed fully to the
floor.
4. Turn the ignition switch to the “ON” position
and check the operation of the warning
and indicator lights. Refer to the
“Warning and indicator lights” section
(chapter 3).
5. Turn the ignition switch to the “START”
position without depressing the accelerator
pedal. Release the key immediately after
the engine has started.
If the engine does not start, try the following.
1)Turn the ignition switch to the “OFF”
position and wait for at least 10 seconds.
After checking that the parking
brake is firmly set, turn the ignition
switch to the “START” position while depressing
the accelerator pedal slightly
(about a quarter of the full stroke). Release
the accelerator pedal as soon as
the engine starts.
2)If this fails to start the engine, turn the
ignition switch back to the “OFF” position
Then fully depress the accelerator pedal
and turn the ignition switch to the
“START” position. If the engine starts,
quickly release the accelerator pedal.
3)If this fails to start the engine, turn the
ignition switch again to the “OFF” position.
After waiting for 10 seconds or
longer, turn the ignition switch to the
“START” position without depressing
4)If the engine still refuses to start, contact
your nearest SUBARU dealer for
assistance.
6. Confirm that all warning and indicator
lights have gone off after the engine has
started. The fuel injection system automatically
lowers the idle speed as the engine
warms up.
