Am mai "studiat" intre timp feature-urile MerpMod-ului
sa inteleg de ce exista multitudinea de harti posibile
Ideea este ca se ofera si masinilor fara SI Drive posibilitatea de a avea harti schimbabile intre ele atat automat (in functie de un sensor care "recunoaste" tipul de benzina din rezervor) sau de catre sofer prin anumita combinatie de "pedale si butoane" sau din soft.
Pun mai jos o bucata dintr-un readme de la merpmod despre cum functioneaza/se face schimbul intre harti de catre sofer si alte cateva chestii:
MerpMod Programming Mode
Entering and Exiting
Initial Requirements:
+Engine off
+Clutch out
+Brake out
+Gas out
+Defog Switch off
1. Press the brake pedal.
2. Fully press and depress the gas pedal three times.
The CEL should now be flashing.
To exit programming mode, press the clutch in.
Readout, Selection, and Adjustment
Programming mode uses the CEL light to read out the current menu item and the current value of the selected menu item.
The current menu item is indicated by the count of SLOW flashes.
The current value is indicated by the count of FAST flashes.
To select the next menu item, press the cruise control resume button.
To select the previous menu item, press the cruise control resume button.
To increase the value associated with the current menu item, press and depress the gas pedal.
To decrease the value associated with the current menu item, press and depress the brake pedal.
Menu Items
1. Map Switch (Intelligent / Sport / Sport Sharp)
2. Map Blending (Map 1 / Map 2)
3. Launch Control Adjust
4. IAM Adjust
5. Valet Mode
1. Map Switch
The currently selected map is displayed using the following values:
Intelligent: 1 flash
Sport: 2 flashes
Sport Sharp: 3 flashes
2. Map Blending
The current map blending ratio is displayed using a value of 1-11 where:
1 flash = 1.0 (Map 1)
2 flashes = 1.1 (Blending)
3 flashes = 1.2 (Blending)
... (Blending)
11 flashes = 2.0 (Map 2)
The current launch control RPM is displayed in ranges of 1000 RPM where:
1 flash = 1000-2000 RPM
2 flashes = 2000-3000 RPM
3 flashes = 3000-4000 RPM
