Subaru Impreza GC *STi Swap*
Răspuns: Subaru Impreza GC *STi Swap*
« Reply #1560 on: January 22, 2015, 19:55:56 PM »
Eu cred ca va fi, pentru ca vorbim de un sistem care nu este complet etans. Vom vedea. Oricum, nu ma astept la diferente majore, ci poate vor aparea si la mine acele plusuri pe care le are Tom.
« Reply #1561 on: January 22, 2015, 22:03:23 PM »
Chiar te rog sa revii cu valorile pe care le vei gasi acum, dupa reparatie, sunt curios daca am rationat corect :)
« Reply #1562 on: January 23, 2015, 01:03:02 AM »
eu pot sa iti zic in psi daca te ajuta senzor pus sus (oricum presiunea depinde mult si de uleiul folosit)
deci, cald relanti in jur la 21psi(+/-1) - am vazut minim 18psi la cald /relanti dupa chinuiala maxima a masinii mult timp, dar mai sus creste odata cu turatia pana in jur la 85psi(+/-5)
iar rece cum e acum afara la prima pornire vad in jur la 100psi...
« Reply #1563 on: January 23, 2015, 18:40:41 PM »
Ms de info baieti ! O sa revin si eu cu valorile mele dupa ce pun ceasul!
« Last Edit: January 23, 2015, 18:43:39 PM by malakay »
« Reply #1564 on: January 30, 2015, 19:24:17 PM »
Am primit si pompa sper sa pot sa o montez weekendul asta !
« Reply #1565 on: January 30, 2015, 20:27:09 PM »
Daca nu poti da mi o mie...
« Reply #1566 on: January 30, 2015, 22:07:57 PM »
iti fac pret bun la aia de sti oem ;D !
« Reply #1567 on: January 30, 2015, 22:31:55 PM »
In CHF ?
« Reply #1568 on: February 14, 2015, 16:40:01 PM »
am schimbat pompa de benz , am pus fetele de usi , mi-am facut intr-un final si sistemul de intercooler water spray home made  ;D
« Last Edit: February 14, 2015, 23:29:01 PM by malakay »
« Reply #1569 on: February 15, 2015, 17:42:13 PM »
 ;D cateaua e happy cu noua pompa
l.e am modificat dimensiunea
« Last Edit: February 16, 2015, 01:03:05 AM by malakay »
« Reply #1570 on: February 15, 2015, 20:18:48 PM »
nu vad bine in imagine cat este IAM ? 16 ?
« Reply #1571 on: February 16, 2015, 00:57:12 AM »
DA  este 16  si este doar un mic knock -1.05
« Reply #1572 on: February 16, 2015, 19:13:09 PM »
da, arata foarte bine in acest caz :)
« Reply #1573 on: February 19, 2015, 19:59:38 PM »
Cu fratili !  8)
« Reply #1574 on: March 06, 2015, 15:27:45 PM »
« Reply #1575 on: March 09, 2015, 19:44:14 PM »
Am avut o mica surpriza au decedat bujiile si am comandat altele ngk NGK PFR7B (multumesc fxt2.5 ) cu ocazia asta am luat si o compresie 9 pe toti cilindri ! Multumesc lui 2xghe ca mi-a schimbat bujiile !
  • 1806
« Reply #1576 on: March 09, 2015, 20:14:01 PM »
Macar atat:))
« Reply #1577 on: March 09, 2015, 20:19:17 PM »
9????? Asa de mult?
« Reply #1578 on: March 10, 2015, 15:55:44 PM »
da ... si eu am zis ca e mult dar din ce am vaz pe net cam aia e 9 e bine
« Reply #1579 on: March 11, 2015, 10:39:30 AM »
Asa e Victor, 9 este ok. Atat mi-a iesit si mie la ultimul test de compresie facut la Exelixis.
