Hello again...
Inca un Subaru ... Multumesc mult Malakay si Tom!!!!
Din pacate avem multe semne de intrebare dar sigur sunt cateva persoane care cunosc masina mai bine decat mine...
Pe scurt :
Subaru Impreza GDF WRX STI
An de fabricatie : 2007
Km : approx. 47000km
UPDATE 10.08.2015
UPDATE 15.09.2015
UPDATE 15.07.2016
UPDATE 13.11.2016
Engine EJ25 (420CP / 500Nm) to be changed
Injectors DeatschWerks 850cc / 1000cc
Sard rampe injectoare
Vibrochen RCM
Biele Arrow / RCM
Pistoane SuperTech 100
Axe Came Tomei
Turbo Turbodynamics MD555-500
Actuator Forge Motorsport EJ207 JDM V9 swap JDM Spec C Twin Scroll
IHI Turbo VF37
GrimmSpeed Boost Solenoid
DeatschWerks Injectors 750cc 21S-01-0750-4ID1000cc injectors
Sard rampe injectoare Cosworth rampe injectoare
RCM Timming Belt Kit
HKS Kevlar Timing Belt
HKS V-Belt Air Co 24996-AK007
HKS V-Belt Power Steering 24996-AK013
Summit lightweight pulleys kit
RCM Timing Belt Kit
Mocal Oil Cooler Kit
(AN10PL) AN10PL ADAPTOR
(236-9010) 236-9010 FITTING 90GR D10
OEM - Water pump
Mishimoto 68 termostat
Mishimoto Radiator X-Line
Mishimoto Aluminum Fan Shroud Kit
Samco hoses kit
Racingline modina
RCM - 10mm Oil Pump
HKS Intake / Air Filter
Cosworth intake manifold
OEM Genuine Engine Gasket kit
STI GrpN STI engine mount
FMIC Greddy
BOV Tial
HKS twinscroll downpipe
Invidia exhaust
Transmission STI 6MT DCCD
Triple plate ATS&Across - CarboneticsXTD Stage 3 + volanta OEM volanta
APR Racing clutch
STI GroupN STI gearbox mount
Whiteline front gearbox cross member pad bushing
Kartboy Shifter Bushing Combo
Brakes & Wheels Front Brembo calipers
Discuri DBA 4000 XS 4654XS-10
Placute Ferodo DS 2500
Rear Brembo calipers
Discuri DBA 4000 XS 4655XS-10
Handbrake Ferodo Premier
Wheels
Winter OEM WRX STI BBS 17x8"; 5x114.3 PCD, 8.61Kg
Tyres 225/45R17
Summer EvoCorse 18"; 5x114.3 PCD
Tyres 235/40R18
ARP bolts front & rear
Handling & Suspension Bilstein B16 BC Racing RH Type
Rulmenti fata
Rulmenti spate VKBA3955
Front upper strut brace
Rear upper strut brace
Rear lower strut brace 22mm - Cusco
Bielete stabilizatore spate Perrin
Summit - cadru de rigidizare fata
Summit - set brate de rigidizare
Summit - cadru de rigidizare cutie de viteze
Summit - cadru de rigidizare punte fata
Summit - rigidizari "T" braces punte spate
Summit - rigidizare diferential spate
Summit - fender reinforcement SBTA9601R
Summit - rear pillow ball
Capete de bara Whiteline
Pivoti Whiteline
Bielete stabilizatoare fata Whiteline
(PFR69-111) PFR69-111 BUCSA POWERFLEX
(PFR69-115) PFR69-115 BUCSA POWERFLEX
(PFR69-110) PFR69-110 BUCSA
(20540AA001) 20540AA001 BOLT BRAT
(20560AA030) 20560AA030 SAIBA
(900335056) 900335056 SAIBA
(902350006) 902350006 PIULITA
(20560AA000) 20560AA000 SUBARU OE
(901000110) 901000110 BOLT OE
(901000109) 901000109 BOLT
(20254FE000) 20254FE000 BUCSA
(20530AA020) 20530AA020 CAP OE
(20540AA080) 20540AA080 SUBARU OE
Interior & AudioZeitronix ZT2 with LCD display : Wideband Air Fuel Ratio Meter and Engine Datalogging Systems
Cusco Roll Cage - de montat
Vopsitorie Roll Cage
Scaune fata Sparco
Centuri fata 4 pct Sparco
STI Genome gauges STRI gauges : boost / oil temp / oil press
ATI gauges pod
HU : Alpine INE-W990BT
Amplificator : Alpine PDX-V9
Dif usi fata : Ground Zero Iridium GZIC 650FX
Dif usi spate : ANULATE
Dif luneta : Ground Zero Radioactive GZRF 69AL
Subwoofer : Alpine SWR-1023D cu incinta custom in roata de rezerva, ca sa nu pierdem din utilitatea portbagajului
Cabluri semnal / alimentare : Ground Zero
Exterior Body kit WRC
forum image hostingMORE TO COME !!!
Cei care detin informatii despre aceasta masina, VA ROG nu va abtineti ...
