STI '07 alias "Galeata Albastra"
Răspuns: STI '07 alias "Galeata Albastra"
« Reply #120 on: April 27, 2016, 22:16:04 PM »
:D
« Reply #121 on: April 27, 2016, 23:19:33 PM »
Cum o fi sa ai 2 masini de vis...
« Reply #122 on: April 28, 2016, 08:40:32 AM »
+ 2 de vis mai mic  ;)
Spor la treaba, Dani!
daniel.gugu
  • 1384
  • Forester & Impreza
    • http://www.gg-dc.ro/
« Reply #123 on: April 28, 2016, 16:17:11 PM »
Si acum partea cea mai grea ... timp de asteptare 4-5 saptamani
2.5 block converted to CDB rebored and faces skimmed
new heat treated crank
acl race series bearings
new crank seals
Williams H beam rods, arp bolts
Mahle 4032 low expansion forged pistons
new 11mm oil pump
Subaru Impreza Type R - GOOFY
« Reply #124 on: April 28, 2016, 16:22:25 PM »
daca iei short block, nu vine deja ansamblat tot in el - cuzineti pistoane biele etc? lista de piese e cu ce contine blocul?
cine o sa mestereasca la motor?
« Last Edit: April 28, 2016, 16:24:39 PM by moguai »
daniel.gugu
  • 1384
« Reply #125 on: April 28, 2016, 16:48:47 PM »
sa vedem ... ori vine short block -ul asamblat, ori pleaca masina la el ...
inca cercetam/negociem...
  • 4032
« Reply #126 on: April 28, 2016, 16:58:23 PM »
te-ai apucat de engine rebuild ? :)
daniel.gugu
  • 1384
« Reply #127 on: April 28, 2016, 17:06:45 PM »
 :'( :'( :'( si asta nu e totul ... din pacate ...
« Reply #128 on: April 28, 2016, 17:08:38 PM »
succes si spor la bani...
  • 14035
« Reply #129 on: April 28, 2016, 17:09:43 PM »
Deja este obsesie sau masochism sa tii atatea masini la care ai nevoie de reparatii capitale.
Eu zic sa le vopsesti frumos si sa punem de un muzeu. Nu se uita nimeni la motor :D
« Reply #130 on: April 28, 2016, 17:53:14 PM »
2.5 cdb la turbina ta si ce vrei tu nu o sa aiba cooling corespunzator niciodata in configul acutal, mai mult trebuie facuta lipirea pe camasa exterioara foarte dichisit ca in timp sa nu se desprinda si sa crape blocul in camera, refoloseste vibrochenul tau din motorul actual, heat treated nu rezolvi nimc, ala care il ai acum este de la RCM tratat cu nitrit luat de mine, iar 11mm oil pump nu este ce trebuie, o sa ramai fara oil flow sus in ture, mergi mai degraba pe o pompa de 10mm
clau
  • 166
« Reply #131 on: April 28, 2016, 18:16:00 PM »
Unde faci motorul in uk ? Faci si conversia la prezoane de chiuloasa de 14mm ?
daniel.gugu
  • 1384
« Reply #132 on: April 28, 2016, 19:06:56 PM »
Tom : 2.5 cdb + turbina mea + oil cooler kit, presupun ca ar rezolva problema. Sa nu uitam ca si radiatorul de apa e marit, parca.
daniel.gugu
  • 1384
« Reply #133 on: April 28, 2016, 19:26:59 PM »
La Williams Motorsport...
daniel.gugu
  • 1384
« Reply #134 on: April 29, 2016, 06:05:28 AM »
Inca nu este masochism...
Galeata va deveni masina de strada, cu ceva fitze pe ea.
daniel.gugu
  • 1384
« Reply #135 on: May 06, 2016, 19:58:04 PM »
Sa speram ca avem vreme buna in weekend...
photo host
daniel.gugu
  • 1384
« Reply #136 on: May 13, 2016, 23:52:45 PM »
Acum ne putem apuca de desfacut...
uploadimage
« Reply #137 on: May 15, 2016, 12:19:57 PM »
sa te bucuri de abgreiduri :)
daniel.gugu
  • 1384
« Reply #138 on: May 16, 2016, 13:57:13 PM »
Mersi mersi ... Incet incet ajungem cu ea in parametrii doriti ...
daniel.gugu
  • 1384
« Reply #139 on: May 19, 2016, 06:27:42 AM »
In speranta ca am luat decizia corecta :
- EJ207 STi v9 JDM twin scroll complete engine
- HKS kevlar cambelt kit
- Genuine Engine Gasket kit
- GrpN STi engine and gear mount
- HKS air filter
- HKS powered steering belts
- STi genome gauges
Ne pregatim de swap... Ar mai trebui ceva?
- in cautare de volanta + Clutch. Ceva recomandari?
Sa pastrez kitt-ul de twin scroll sau sa transfer ce am acum pe 2.5 (serpi, turbo, baia de ulei, turbo)?
Pentru max. 400cp sa iau si un stroker sau merg si internele OEM?
« Last Edit: May 19, 2016, 06:38:31 AM by daniel.gugu »
