« Reply #280 on: January 21, 2020, 21:19:56 PM »
Ezac
« Reply #281 on: January 21, 2020, 22:32:11 PM »
De la Whiteline avem asa:
1. KCA359M anti-lift/caster kit RACE
2. W92829 gearbox xmember mount
3. KSB750 rear subframe lock kit
4. W52837A bush kit low.inner-front
5. KSB511 rear strut bar
6. KCA313 roll-centre/bump-str. adjust kit
7. BSF33XZ 24mm front sway bar
8. BSF37XZ 24mm rear sway bar
9. 2x KLC139 adjustable end-links
10. KBR21-24 rear seay bar mounts
Si “Black Series” de la Powerflex:
1. PFF69-109KBLK steering rack mount
2. PFR69-115BLK tie bar to hub rear bush
3. PFR69-117BLK tie bar to hub front bush
4. PFR69-118BLK rr sub front outrigger L
5. PFR69-124BLK rr sub front outrigger R
6. PFR69-122BLK rear diff mount bushes
Urmeaza sa ma caut de pietre la rinichi ca sa nu am vreo surpriza!  ;D ;D
« Reply #282 on: January 21, 2020, 23:25:42 PM »
Pfff. Daca nu ai pietre o sa faci...
  • 852
« Reply #283 on: January 22, 2020, 11:57:01 AM »
Mersi de info!
Dacă ai pietre o sa le spargi :o
Mișto lucrătura :)
« Reply #284 on: January 22, 2020, 12:07:13 PM »
Recunoasteti materialul:
  • 5287
« Reply #285 on: January 22, 2020, 12:13:22 PM »
Intake spacers  ::)
« Reply #286 on: January 22, 2020, 12:21:05 PM »
Brici!
Ai un os!
« Reply #287 on: January 22, 2020, 16:27:42 PM »
ce dimensiune ? daca ies la un pret decent vreau si eu un set !
« Reply #288 on: January 22, 2020, 17:20:07 PM »
8mm, cat este recomandat incat sa nu faci alte modificari.
O sa fac un pachet de distantieri+suruburi, clar sub pretul celor consacrati pe piata.
Cu garniturile cred ca se poate descurca fiecare usor.
Pot face si alte grosimi, pana la 50mm.
« Reply #289 on: January 23, 2020, 13:42:42 PM »
O alta zi si gramada de piese nemontate creste:
Front brake air duct plates
Anti Fuel Surge
« Reply #290 on: January 23, 2020, 14:05:37 PM »
Si cea mai mare transa de piese OEM a sosit (tot ce inseamna furtunuri, ganituri, o-ring-uri, clips-uri, filtre, etc.):
15208AA100   filtru ulei                 x5
807615182   furtun pompa apa jos             x1
807612011   furtun pompa apa sus            x1
11126AA000   garnitura baie ulei                  x6
806910170   o-ring joja jos                x2
11122AA340           o-ring retur ulei baie     x1
806908080   o-ring joja sus                x1
806917070   o-ring sorb ulei         x1
26238FE000   bleeder etrier           x8
901120103   surub etrier fata       x4
901120102   surub etrier spate     x4
806786040   simering arbore spate    x1
10931AA010   garnitura capac OCV                  x2
13270AA152              garnitura dreapta capac chiulasa        x1
13272AA075   garnitura stanga capac chiulasa          x1
13293AA051   garnitura bujie      x4
13271AA071   garnitura surub capac chiulasa        x16
14035AA421   garnitura galerie admisie           x2
44616AA290   garnitura galerie evac.-chiulasa     x2
44011FE010   garnitura uppipe-turbo                 x1
44011FE020   garnitura turbo-downpipe                x1
902370009   piulita turbo   x5
16175AA223   garnitura clapeta             x1
22659AA120   garnitura IACV              x1
44059AA030   surub galerie evac.-uppipe      x1
806212020   rulment pilot                            x1
0951BG110   furtun benzina rampa            x2
807707111   furtun benzina rampa               x2
45161FE050   inlet radiator                     x1
45161AE020   outlet radiator                 x1
45137AE003   buson vas expansiune   x1
11810AA000   valva PCV                  x1
99071AB420   furtun vacuum           x1
21896AA072   garnitura BOV                    x1
21896AA010   garnitura Y intercooler                      x2
11815AB301   furtun PCV dr.                              x1
11815AB560   furtun PCV st.                         x1
11815AB311   furtun PCV st.                           x1
803942020   garnitura buson umplere ulei      x1
21191KA000   o-ring gat umplere ulei                     x1
807611031   furtun racitor ulei si iesire p apa    x2
21370KA001   garnitura racitor ulei                            x1
800910550   prezon evac. chiulasa                 x1
909140007   clips bara fata+spate  x34
909130059   clips bara fata   x4
81910TA100   clips bara fata-aripa      x2
57728AC090   clips scuturi si carenaje      x17
59122AC030   clips filet carenaj  x2
59122FA010   clips filet carenaj     x8
46064AE000   clips filet carenaj     x10
38353AA050   garnitura capac dif spate       x1
806992020   o-ring flanse dif spate         x2
806716070   simering timonerie    x1
16546AA020   filtru aer       x2
806912140   o-ring joja cutie   x1
803926090   garnitura buson cutie   x1
« Reply #291 on: January 23, 2020, 17:08:12 PM »
Da ce ti-a venit?
« Reply #292 on: January 23, 2020, 17:30:35 PM »
Eu repet , mai bine faceai un lizing si iti luai si tu o masina noo ca tot omu care se respecta el pe el cand isi ia masina noo .
Ce atata pasiune neinteleasa ? Ce atata surubareala ? #autofzabox sinching ca sa zic asa....
Mai exact , ce iti trebuie tie asta daca mie nu ?
P.S. Daca ramane ceva in plus , faci un platoas ?
« Reply #293 on: January 23, 2020, 20:22:33 PM »
Eu am întrebat pentru că știam despre motor că e in toate mințile. Acum văd garnituri de tot felul. Eu nu as umbla dacă nu ar fi nevoie.
« Reply #294 on: January 23, 2020, 20:31:37 PM »
Pentru ca Rotac.
Referitor la motor si transmisie, nu imi permit sa le distrug de la vreo chestie gen garnitura, furtun...
Iar in rest, vreau sa stea ca pe sine si sa franeze decent.
Plus ca daca viata e frumoasa, de ce sa nu ne-o complicam un pic?!
@Celalalt, pe bune ca maine mi-as face un leasing pentru masina de zi cu zi, dar habar n-am ce as putea sa iau mai practic decat SH-ul. Si mai e un aspect: parca nu am chef sa stau sa ma uit toata ziua daca mi-a atins careva cu portiera masina.
« Reply #295 on: January 23, 2020, 20:36:49 PM »
doo SeHasuri ;)
« Reply #296 on: January 23, 2020, 21:07:57 PM »
Tu nu vrei masina ca n ai bani. Esti sărăkie. Te cârpești ca mine ca si eu sunt sărăkie.
Acum serios , repet si eu am aceeasi problema. Nu ma incanta nimic la masinile noi. Cochetam cu Mazda , prea comuna deja. Alfa , e opzejdemii , cacat . Porșu ala suvuleț la fel. Șaptejopzejdemii.
Pisihologic nu pot sa concep o astfel de suma si cum spui tu , sa ma uit daca mi au zgariat o sau sa ma urc cu geaca plina de rumegus in ea. Ca deh , ma mai si murdaresc la munca... Si chiar si asa , e o masina da o n balarii , nu ne dam pe Dorobanti la opulenta , s'tem oameni normali...
« Reply #297 on: January 23, 2020, 21:20:15 PM »
Ce cacat atat despre nush ce masini noi.....plm, va plac astea si mai si functioneaza.....ce altceva mai vreti?Enjoy them!!!
« Reply #298 on: January 23, 2020, 21:23:41 PM »
A mea ma enerveaza. E prea zgomotoasa. Vand evacuare inocs șapteșșase mm custom pe comandă.
« Reply #299 on: January 23, 2020, 21:27:46 PM »
pe tine te enerveza orice
doape in urechi si ai rezolvat problema ;)
