  • 5133
« Reply #520 on: June 01, 2020, 11:29:04 AM »
Carenaj - prea joasa.
« Reply #521 on: June 01, 2020, 11:31:22 AM »
Acolo carenajul vine 10mm spre amortizor, nu e la limita oalei. E loc de modificat.
« Reply #522 on: June 02, 2020, 22:25:25 PM »
6
« Last Edit: August 28, 2020, 10:51:41 AM by Pfaizzzer »
« Reply #523 on: June 02, 2020, 23:00:43 PM »
Interesant. De urmarit rezultatul dupa gaurit BOV-ul.
« Reply #524 on: June 03, 2020, 15:17:00 PM »
7
« Last Edit: August 28, 2020, 10:52:05 AM by Pfaizzzer »
« Reply #525 on: June 03, 2020, 19:14:35 PM »
8
« Last Edit: August 28, 2020, 10:52:43 AM by Pfaizzzer »
  • 4033
« Reply #526 on: June 03, 2020, 20:10:32 PM »
daca reiscar ai vrut...reiscar ai ... crezi ca mergi oriunde cu ea ? :)
« Reply #527 on: June 03, 2020, 20:50:58 PM »
Nici macar la reis nu merg!  :'(
  • 4033
« Reply #528 on: June 03, 2020, 21:27:26 PM »
no biiine ... stiu piloti cu reiscar care tot o pregatesc si nu-i gata de 2 ani ... deci tu stai super ok :)
« Reply #529 on: June 03, 2020, 21:39:56 PM »
Pai cum crezi ca m-am consolat eu? Vorbind cu “pilotii”!  ;D ;D ;D
  • 5133
« Reply #530 on: June 03, 2020, 22:40:47 PM »
Despre pocnitura, asigura-te ca ai pus colierele de limitare miscare laterala pe bare la 3-4mm de bucse. Presupun ca pe spate ai pus doar pe dreapta.
Si evidentul, misca tare de toba in laterale, vezi daca apare sunetul.
« Reply #531 on: June 04, 2020, 10:15:48 AM »
Nu mi-au dat decat doua colier pe care le-am pus pe fata...de aia banuiesc ca e bara antiruliu de vina.
Am verificat evacuarea si e tzapana.
« Reply #532 on: June 04, 2020, 10:23:25 AM »
Asa trosnea si la Tom la blob-ul negru din cate tin mine. Prea mult plastic si metal pe metal unde candva era cauciuc :) Te obisnuiesti si aia e.
  • 1319
« Reply #533 on: June 04, 2020, 10:28:13 AM »
Confirm ca zgomotele sunt ceva obisnuit cand ai bucsi poliuretan vs cauciuc.
Si la mine e la fel (ma refer la mers pe drumuri neasfaltate, pietruite). Mai ales cu anvelopele de vara (mai subtiri si mai plasticoase vs cele de iarna).
Dupa ce montez AT-urile sper sa fie usor mai pufoasa pe ulite neasfaltate :)
« Reply #534 on: June 04, 2020, 10:28:56 AM »
E ca si cum s-ar plimba ceva stanga-dreapta...nu e trosneala, e poc-poc.
Prima data am verificat daca am uitat ceva in compartimentul rotii de rezerva, ca sa iti faci o idee de cum suna.
« Reply #535 on: June 04, 2020, 10:30:19 AM »
Face poc in viraje stranse pe asfalt perfect. Eu zic ca Mutli are dreptate cu colierul de la bara spate...pe care nu il am.
  • 1319
« Reply #536 on: June 04, 2020, 10:31:36 AM »
Atunci e alta cauza, da.
  • 5133
« Reply #537 on: June 04, 2020, 10:51:53 AM »
Nu cred sa fie colierul, dar afli dupa ce vad ce stoc de coliere Whiteline mai am acasa.
Adica nu inteleg ce ar putea atinge cand se plimba bara cativa mm.
PS: la mine nu pocneste nimic.
« Last Edit: June 04, 2020, 10:52:24 AM by Muttley »
« Reply #538 on: June 04, 2020, 11:21:51 AM »
Se vad urme de vaselina pe bara de circa 40mm si e maxim spre dreapta.
Nu uita ca eu am altfel de prinderi la bielete, cu un suport separat de brat (RA-R) si poate nu ii convine barei ca am lasat bieletele oem.
« Reply #539 on: June 04, 2020, 11:24:00 AM »
Meanwhile in San Pedro:
“2” & warranty sticker
