Conversie g/s la hp
Conversie g/s la hp
Conversie g/s la hp
« on: January 12, 2022, 11:47:57 AM »
Preluat de pe forumul nasioc. Sunt mai multi useri care au preluat informatii din mai multe locuri asa ca nu as putea spune clar cine este autorul, dar multumim!
mafv   g/s   lb/min    hp
2.00   16.81   2.22   22
2.05   18.33   2.42   24
2.10   19.93   2.64   26
2.15   21.62   2.86   29
2.20   23.41   3.10   31
2.25   25.30   3.35   33
2.30   27.29   3.61   36
2.35   29.38   3.89   39
2.40   31.58   4.18   42
2.45   33.89   4.48   45
2.50   36.31   4.80   48
2.55   38.85   5.14   51
2.60   41.50   5.49   55
2.65   44.28   5.86   59
2.70   47.17   6.24   62
2.75   50.19   6.64   66
2.80   53.34   7.06   71
2.85   56.62   7.49   75
2.90   60.04   7.94   79
2.95   63.59   8.41   84
3.00   67.27   8.90   89
3.05   71.10   9.41   94
3.10   75.08   9.93   99
3.15   79.20   10.48   105
3.20   83.47   11.04   110
3.25   87.90   11.63   116
3.30   92.47   12.23   122
3.35   97.21   12.86   129
3.40   102.11   13.51   135
3.45   107.17   14.18   142
3.50   112.39   14.87   149
3.55   117.79   15.58   156
3.60   123.35   16.32   163
3.65   129.09   17.08   171
3.70   135.01   17.86   179
3.75   141.10   18.67   187
3.80   147.38   19.50   195
3.85   153.84   20.35   204
3.90   160.49   21.23   212
3.95   167.33   22.14   221
4.00   174.36   23.07   231
4.05   181.58   24.02   240
4.10   189.01   25.01   250
4.15   196.63   26.01   260
4.20   204.46   27.05   271
4.25   212.50   28.11   281
4.30   220.74   29.20   292
4.35   229.20   30.32   303
4.40   237.87   31.47   315
4.45   246.76   32.65   326
4.50   255.86   33.85   339
4.55   265.19   35.09   351
4.60   274.75   36.35   363
4.65   284.53   37.64   376
4.70   294.54   38.97   390
4.75   304.79   40.32   403
4.80   315.27   41.71   417
4.85   325.99   43.13   431
4.90   336.95   44.58   446
4.95   348.16   46.06   461
5.00   359.61   47.58   476
5.05   371.31   49.12   491
mass(g/s)=3.5906*mafv^3-4.0038*mafv^2+2.2571*mafv-0.4089
hp este estimare pe baza formulei 10hp/(1lb/min)
Re: Conversie g/s la hp
« Reply #1 on: January 12, 2022, 18:34:12 PM »
Interesant..eu monitorizez si MAF-ul si pe cruise la 145 sau 150km/h aveam 96-97g/s...deci 122cp din 150😅.
« Reply #2 on: January 12, 2022, 18:41:24 PM »
Ce turatie? Ca nu te astepti sa ai toti caii oricand oricum.
« Reply #3 on: January 12, 2022, 19:14:34 PM »
2500 rpm ...trecute fix :)
  • 887
« Reply #4 on: January 12, 2022, 19:20:37 PM »
Mai era de urcat  :D
  • 4033
« Reply #5 on: January 12, 2022, 20:03:15 PM »
nu zice nimeni ca modalitatea asta de estimare e ok pt diesel sau FAuri :)
si la EJuri e ok in anumite conditii ...
  • 4033
« Reply #6 on: January 12, 2022, 20:56:41 PM »
ca idee, STI 2008 nemodificat e dat la ~300hp la motor, masurat la 235-240 cai la roata si in loguri de asemenea vezi 235-240g/s la ~6200rpm deci e prin zona formula 240 / 80 * 100 = 300
si am avut mai multe masini cu modificari masurate si pe dyno si cu +/- 5 cai fata de estimarea data de formula de mai sus dar e important evident ca g/s sa fie o valoare corecta ->  ca daca modifici din cipciuning maf scalingul de exemplu ca sa compensezi o setare de injectoare inexacta sau ca sa obtii un AFR dorit fara sa schimbi target AFR sau ai ceva leak pe partea de aer sau altele de genul evident ca formula not working
de asemenea poti avea valori corecte de g/s dar daca AFR-ul este super bogat sau avansul jos evident again ca nu esti la caii rezultati din formula
sau altfel zis : cu valori corecte de g/s, AFR around 11 si avans la ~2 grade sub limita de knock estimarea functioneaza
« Last Edit: January 12, 2022, 20:58:10 PM by andea79 »
